Units Pump Heat Fan Coil
Showing the single result
Necessary cookies are absolutely essential for the website to function properly. This category only includes cookies that ensures basic functionalities and security features of the website. These cookies do not store any personal information.
Any cookies that may not be particularly necessary for the website to function and is used specifically to collect user personal data via analytics, ads, other embedded contents are termed as non-necessary cookies. It is mandatory to procure user consent prior to running these cookies on your website.
Welcome to the IBM Digital Twin Exchange! Now featuring digital twin downloads to manage connected assets. Dismiss
Currently, an end user has to find or request digital twin content such as Bill of Materials from vendors separately. After receiving a Bill of Materials document in PDF format, the end user may then spend over 20 hours manually entering data into enterprise asset management solutions such as IBM Maximo Asset Management.
The IBM Digital Twin Exchange is a ecosystem for end users to easily search and access many different types of digital resources related to assets. Upon purchasing your digital twin, if the digital twin is compatible with IBM Maximo, an user may import digital twin into IBM Maximo (view demo here). Ultimately, end users would be able to save time, as well as better understand and optimize the performance of installed assets.
Your files are being imported into Maximo. Once your files have imported, you will be prompted to enter your encryption key.
Take a Tour to learn more about the IBM Digital Twin Exchange today!
You must be logged in to report an issue with a Digital Twin.
