• Information
    • About the Digital Twin Exchange
    • Login
0 Items
IBM Digital Twin Exchange
  • Dashboard
  • Exchange
    • Browse
  • My Digital Twins
Select Page
Home / Products tagged “Sensors Encoders Pneumatic Switches Components Controllers Series Programmable Cables Subpanels”
Showing the single result
  • AutomationDirect
    Cables Circuit Protection Fuses Disconnects Communications Drives & Soft Starters Enclosures Subpanels Thermal Management Lighting Field IO HMI […]
    0.00 credit(s)
    Cables Circuit Protection Fuses Disconnects Communications Drives & Soft Starters Enclosures Subpanels Thermal Management Lighting Field IO HMI (Human Machine Interface) Industrial Monitors Motion Control Motor Controls Motors PC-based Control Pneumatic Components Power Products (Electrical) Power Transmission (Mechanical) Process Control & Measurement Programmable Controllers Pushbuttons Switches Indicators Relays Timers Safety Sensors Encoders Stacklights Terminal Blocks Water (Potable) Components Wiring
    Add to Wishlist
    Add to cart
  • Visit Digital Twin Exchange on IBM Marketplace
  • Frequently Asked Questions
  • Contact IBM
Welcome to the IBM Digital Twin Exchange! Now featuring digital twin downloads to manage connected assets. Dismiss
Importing files to Maximo
Your files are being imported into Maximo. Once your files have imported, you will be prompted to enter your encryption key.
Take a Tour to learn more about the IBM Digital Twin Exchange today!
You must be logged in to report an issue with a Digital Twin.
  • Dashboard
  • Exchange
    • Browse
  • My Digital Twins
