lugged gate valve bronze opted double butterfly valve cast iron check valve fully strainer
Showing the single result
Hattersley
Warning: Use of undefined constant WC_Product - assumed 'WC_Product' (this will throw an Error in a future version of PHP) in /var/www/html/wp-content/themes/digital-twin-exchange/functions.php on line 4900.00 credit(s)100 threaded dzr ball valve 100c compression dzr ball valve 100cexs compression dzr ballwith ext stem 100cls compression […]
100 threaded dzr ball valve 100c compression dzr ball valve 100cexs compression dzr ballwith ext stem 100cls compression dz ballwith lockshield 100ct compression dz ballwith t handle 100cyl gas compression dzr balllever pn16 100exs threaded dzr ballwith ext stem 100hu dezincification resistant male hose union threaded end 100ls threaded dzr ballwith lockshield 100t threaded dzr ballwith t handle 100yl threaded dzr ballfor gas applications 1013 bronze horizontal lift check valve 107mhu ballwith male union pn32 108c service ball valve 113 full bore broze ball valve 1200dr valve 1432 pn20 threaded 1432c pn16 threaded 1432l pn20 threaded low flow 1432m pn20 threaded med flow 1732lpf double regulatinglow flow 1732mpf double regulatingmed flow 1732pf double regulating valve 1807 dzr strainer ballpn25 1807c dzr strainer ballpn16 1807cext dzr strainer ballpn16 1807ext dzr strainer ballpn25 1807l dzr strainer ballpn25 249 brass double check valve 28 cwp bronze gate valve 2900 thermal circulation valve 2910 thermal circulation valve 3047 bronze swing check valve 305 pressure independent controldn10 dn32 305 pressure independent control dn40 dn50 305f pressure independent control dn125 dn150 305f pressure independent control dn200 dn250 305f pressure independent control dn50 dn100 30 dzr brass gate valve 30c bronze compression ended gate valve 30cls bronze compression ended gatewith lockshield 30ls dzr brass gatewith lockshield 33 bronze gate valve 33x bronze gate valve 33xls dzr brass gatewith lockshield 35 bronze gate valve 42 bronze horizontal lift check valve 47 bronze swing check valve 48 bronze oblique swing pattern check valve 4993g steel fully lugged double regulating pn25 4993g steel fully lugged double regulating pn40 49 bronze vertical lift pattern check valve 501 cast iron gate valve 504 cast iron gate valve 609 bronze gate valve 669 bronze gate valve 817 pn16 Y type strainer 817pf bronze strainer 820 pn16 strainer 860 wafer check valve 865 wafer check valve 920 pn16 Y type strainer 953 cast iron with double regulating fea 13 953g cast iron with double regulating fea 973 ductile iron with double regulating fea 13 973G ductile iron with double regulating fea 13 Butterfly4970 ductile iron fully lugged lever opted butterflyss disc Butterfly4970g ductile iron fully lugged gearbox opted butterflyss disc Butterfly4983 pn25 lever opted double regulating valve Butterfly4983G pn25 earbox opted ouble regulating valve Butterfly950 semi lugged lever opted butterfly valve Butterfly950g semi lugged gearbox opted butterfly valve Butterfly950W semi lugged lever opted butterfly valve Butterfly950WG semi lugged gearbox opted butterfly valve Butterfly951 semi lugged lever opted butterfly valve Butterfly951G semi lugged gearbox opted butterfly valve Butterfly970 fully lugged lever opted butterfly valve Butterfly970G fully lugged gearbox opted butterfly valve Butterfly970w fully lugged lever opted butterfly valve Butterfly970WG fully lugged gearbox opted butterfly valve Butterfly971 fully lugged lever opted butterfly valve Butterfly971G fully lugged gearbox opted butterfly valve Butterfly980ansi ductile iron fully lugged butterflyclass 150 export only C31 bronze gate valve C618 bronze gate valve Commissioning5953 semi lugged leaver oppted Commissioning5953G semi lugged leaver oppted Commissioning5973 semi lugged leaver oppted Commissioning5973G semi lugged leaver oppted F300 dpcv flow male ended F400 dpcv flow female ended M2000 flow measurement device M3000 flow measurement device M4000 flow measurement device M511 cast iron gate valve M540 ductile iron gate valve M541 cast iron gate valve M544 cast iron gate valve M549 cast iron gate valve M552 cast iron gate valve M552E cast iron gate valve M650 ductile iron swing pattern check valve M651 cast iron swing pattern check valve M653 cast iron with lever and weight check valve MH733 double regulating valve MH737 double regulating valve R300 dpcv return male ended R400 dpcv return female ended S1832 fixed orifice double regulating all types S1832l fixed orifice double regulating low flow S1832M fixed orifice double regulating med flow Strainer807 bronze Y type strainer valve Strainer907 bronze Y type strainer valve
Add to cart
