• Information
    • About the Digital Twin Exchange
    • Login
0 Items
IBM Digital Twin Exchange
  • Dashboard
  • Exchange
    • Browse
  • My Digital Twins
Select Page
Home / Products tagged “HoKa sockets Sound attenuator flanges mm outlet valve Damper Flexible”
Showing the single result
  • Hoka
    Bend Branch outlet Double sockets Reducer Dampers Butterfly Valves Control valves Flange Flexible connector Sound attenuator Enser deflector […]
    0.00 credit(s)
    Bend Branch outlet Double sockets Reducer Dampers Butterfly Valves Control valves Flange Flexible connector Sound attenuator Enser deflector housing Saddle Breeches Tube Outlet Cowl PVC-spiral coiled tube Inlet/Outlet grille Stacking frame Roofhead Back flow damper Shutter valve Through wall Outlet with grille Endcap Cleaning orifice Slot valve
    Add to Wishlist
    Add to cart
  • Visit Digital Twin Exchange on IBM Marketplace
  • Frequently Asked Questions
  • Contact IBM
Welcome to the IBM Digital Twin Exchange! Now featuring digital twin downloads to manage connected assets. Dismiss
Importing files to Maximo
Your files are being imported into Maximo. Once your files have imported, you will be prompted to enter your encryption key.
Take a Tour to learn more about the IBM Digital Twin Exchange today!
You must be logged in to report an issue with a Digital Twin.
  • Dashboard
  • Exchange
    • Browse
  • My Digital Twins
